Home Forum Ask A Member Prop for 1966 5HP Evinrude
  • #11426
    chipster303
      Does anyone have or know who has a prop for a 1966 5HP Evinrude? It is 8×7 1/2, Left hand, 1/2 inch shaft dia.
      #83907
      outbdnut2
        Try posting a "Wanted" ad on the classified board here. The ad is free and somebody should have one. Props for the 5.5 HP going back to 1954 will work. So will the 9.5 HP props, but they will likely have too much pitch. If you get an older one, watch out for shear pin location. Some had the pin out under a rubber propeller nut cover and some had it underneath the prop.
        I think in 1966, your Evinrude was a 6 HP, but regardless, if you can’t find a used prop, Propco has new ones for $73, in a choice of pitch and 2 or 3 blade. I’ve bought several props from them and they have all been good.
        http://propcopropellers.com/evinrude—johnson.html
        #83909
          With all due respect to outboardnut2, that is incorrect information. The 5hp was a non-shift motor and takes a different prop than the 5.5-etc. Not only that, people have asked about them before, and it appears the prop is very rare. Good luck in your search, and don’t give up hope. Perhaps somebody has one for you.
          #83924
          chipster303
            Thank you both for the information! I am looking for this prop for a friend and am beginning to realize it is like looking for hen’s teeth. Will post an ad and keep calling around.
            #83925
            nj-boatbuilder57
              eBay to the rescue… https://www.ebay.com/itm/Propeller-for- … Sw7NZbra1C
              #83936
              rmhxruss
                380104 is original prop. N/A from BuRP 2004. Michigan PJ7 012004.
                #83939
                reivertom
                  Just note that if you are talking about the non-shifting 5hp model, the prop is a left hand turn prop. The props from all the shift model 6hp OMCs from the era won’t work unless you want to go backwards all the time. These props are around, but they are much more expensive than the more available ones. I’ve seen some priced for nearly what I gave for my whole motor!
                  #83943
                  fifty20ne
                    Look for a "Michigan Wheel" PJ-7 prop on eBay. I found one there.
                    Or Maybe?
                    https://detroit.craigslist.org/wyn/bpo/ … 30584.html
                    #83988
                    outbdnut2
                      quote FrankR:
                      Frank – Thanks for setting me striaght – I had never heard of that 5 HP model.
                      chipster303
                        Thanks for all your help! Just ordered that one on Ebay. Expensive, but can’t run without one. I appreciate all your responses!
                        Chip
