Hi Everyone!
I bought this NOS higher pitch bronze prop a while ago thinking it would be a cool replacement for stock prop on my 1970 Viking 9.6hp outboard (same as the Ward’s Sea King model). I was told that it fit Chrysler 9.9 and it looked good so I took a chance on it. I was under the understanding that the 9.9 and 9.6 were the same motor… yes? or No? The shaft and splines fit perfectly but the prop hub is a little too long and wide. I couldn’t find the id #s P326B anywhere in reference data. I’m assuming the “B” at the end refers to Bronze… Although i can’t use it right now i’m curious to figure out what it does fit and what the make is. Any info would be appreciated! Thanks!
