I have a 25hp 1969 Johnson (25R69D) that I believe has a spun prop. Is it worth trying to have the prop repaired or would I be better off replacing the prop? If replacement is the better option, does anyone have any recommendations for a replacement? Would it be wise to stick with a factory prop or is an aftermarket part the better option?
Thanks for the info collectorinspector. I think that will go ahead just buy a new prop. These are the two props that I was looking at that have the same dia x pitch as my current prop:
