Home Forum Ask A Member QD 10 HP Recoil Starters Rattle
  • #243257
    outbdnut2
      I have recoil starters on 1963 and 1958 10 HP Johnsons that rattle at mid to high throttle. On the 1963, I swapped on a recoil from a 1960 parts motor – same noise, but slightly less. If I take the recoils off and start it with a detached rope, the rattle goes away. There is no wear on the flywheels to indicate something rubbing. I can wiggle the pulley the rope is wound on up and down and hear the rattle on all of them. It’s probably a non-issue but I’d like to quiet them down and maybe stop further wear. On the 1960 and 1963, I tried removing the hardware directly behind the pull handle (part #18 in the link below) but that wasn’t the rattle either. Can I add a spacer washer to take up the rope pulley wobble to quiet them down? Is there some other part that I should replace? Link to exploded view below (basically the same for all three years except for the part behind the pull handle).
      Thanks! Dave
      http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1963&hp=10&model=QD-24&manufacturer=Johnson&section=Starter+Group
      • This topic was modified 3 years, 9 months ago by outbdnut2.
      #243259
        Part #6 may be wore, or the inner bore of the rope pulley #6, or both.
        Not sure you can add a washer and still have the pulley turn freely.
        Some thick grease might help for a while between the parts mentioned.
          I had a slight rattle on my ’57 18hp and found the same slight wobble in the rope sheave. I inserted a thin nylon washer between the starter spindle and the spindle washer (#6 and 7 in the diagram) and that took care of the rattle. Don’t know if that’s the right fix but it worked for me. Imagine after a period of use, the nylon washer might wear and need to be replaced but we’ll cross that bridge later.
          • This reply was modified 3 years, 9 months ago by Bob Wight.
          #243285
          russ
            Had the same problem a few weeks ago . Put a washer under each of the recoil 3 recoil posts then tightend up the screws. Worked for me but I could see a small wear mark on flywheel.Maybe worth a try . Good Luck……Russ…
            #243291
              See that long rubber snout on the starter handle? That has a purpose, to jam in between the pulley groove and starter housing and keep it from rattling.
              #243293
              outbdnut2
                Thanks Frank – never thought of that! I’ll check to see if it’s worn too far to do the job.
                • This reply was modified 3 years, 9 months ago by outbdnut2.
                #243374
                  That is the most interesting thing I have heard in a long time! I always wondered why they did that! Having lots of Mark 25 Mercurys, I can safely say that you OMC guys don’t even know what a rattle IS, compared to a Mark 25 recoil, where half the time, the metal pawls are dinging off the metal flywheel…So I guess I never even had a complaint about an OMC recoil….
                  #243383
                  outbdnut2
                    Now you’ve got me thinking…..If that rubber is worn, I’m thinking maybe I can add a piece of rubber gas line that’s close to the OD of the original and an ID that accommodates the rope to replace worn piece. These are motors I will not use much, so not worth a new handle if I can’t find a good one on one of my OMC parts motors. I’m thinking maybe I can glue rubber gas line to the rope with a cement that stays flexible, like shoe-goo? Anyone have thoughts on this? I see Marineengine has replacement handles for $23.49 for the 1963 10 HP that may also work on some of the other years if I’m ever wanting to do a correct restoration.
                      I’ve considered the hose fix but never tried it. Go for it and let us know
                      #243392
                      David Bartlett
                        I have used a piece of fuel line glued to the handle. Seems to do the trick.
                        David Bartlett
