Home Forum Ask A Member QD-12 Service Bulletin
  • #1804
    steveh
      Before the website crashed, someone posted a service bulletin for multiple motors for which the QD-12 was included. It dealt with having to turn the high-speed needle down all the way to get the motor to run, and the solution was an o-ring in the carburetor if I recall.
      Does anyone have a copy of that service bulletin or know what I am talking about?
      Thanks,
      Steve.
      #18519
      mercuryman
        There is a small round gasket #344037 or #63 on parts list. This gasket fits around jet in center of Carb. It must fit tight when you install the bowl to top of carb. If its not tight the motor will run rich.
        #18521
        steveh
          Mercuryman, thanks for the reply. However, my parts list doesn’t show either of those part numbers.
          #18524
          mercuryman
            That part # is for a 1960 10 hp same part. I make the gasket out of cork material or you can use a O ring. Take the carb apart and you will see what I am talking about.
            #18541
              I use o rings now. I can get the size for you tomorrow.
              #18610
              steveh
                I could use a little more help. My parts diagram for the QD-12 doesn’t show those part numbers. I took the bowl off the carburetor and I don’t see any O-rings or gaskets, other than the one going around the bowl. Maybe that’s the issue if there is supposed to be something in there…
                Do any of you have a photo you could share or a part number that might show up on my parts diagram so I know where this thing is supposed to be?
                Thanks
                Steve.
                #18621
                mercuryman
                  I may be giving you bad info I have a QD15 and if I remember right the QD 12 carb is different and I don’t have parts info for QD 12. Maybe
                  someone else can help, sorry!
                  #18657
                    Here’s the QD 12 carb diagram
                    and some of the part numbers.
                    #18659
                    steveh
                      Mumbles, thank you. I already have that. I’m just not sure what o-ring we’re talking about. I do remember from the original service bulletin that it was an issue and the replacement of the o-ring was the solution. Wish I’d saved that service bulletin when it was posted 🙁
