Home Forum Ask A Member "Scott-Atwater" Firestone 3.6hp 1955
Viewing 10 posts - 21 through 30 (of 38 total)
  • #46165
    nali
      Found everything. Quite ….
      Paint code ? 🙂
      Or should I paint it flat black like a rat rod ? 😛
      #46169
        It’s your motor, do whatever you want with it. Personally, I’d paint it the right color. Reprotint has the correct color paint. http://www.reprotint.com
        #46191
        nali
          Great !
          Thank you.
          Is usually a 12 oz can enough ?
          #46268
          nali
            A few dents on the tank ..
            #47209
            nali
              Head gasket and rings received from http://www.laingsoutboards.com .
              Very nice service and solid box !
              How to do when you need a ring compressor 🙂
              #48015
              nali
                The usual first (re) start.
                https://www.youtube.com/watch?v=ZlsUp1uCtks
                #48196
                nali
                  There’s no water circulation in the engine.
                  The rubber excentric as some wear, so i need to replace it.
                  I can’t find one specific for Scott-Atwater, but this Gale #900040 seems to be the same :
                  http://www.vintageoutboard.com/collecti … ntric-type
                  I also noticed there’s supposed to be O-rings on the water tube, but I’m not sure they are really useful.
                  Do you use any kind of sealer here ?
                  Also, the rotor is not cheap at 25$. Its shape is nice, but it shrinked.
                  Is there any way to have it stretch to the original size ?
                  Thanks.
                  #48250
                  Steve A W
                    Nali
                    AOMCI member Brian Wilcox makes the pump rotors for this motor.
                    I just got one a month or two ago from him. And he’s very reasonable.
                    His email address, baron0418[at]att.net
                    And I think the "b" needs to be capitalized.
                    Good Luck with your motor.
                    Steve A W
                    Member of the MOB chapter.
                    I live in Northwest Indiana
                    #48253
                    nali
                      Thanks a lot Steve for the information.
                      I ve mailed to Douglas Penn,but he is now retired from outboard parts:)
                      It seems rubber can be as new ( and still reliable years after ) by soaking in brake fluid.
                      So i try first this.
                      3.99 for DOT 4, and 25 $ + shipping for an unknow rotor 😛
                      Guess my choice..
                      This motor will run, of course.
                      My goal is to sell it and find a 1927 / 30.
                      Won t make money. for sure 😛
                      #48256
                        That’s shocking news about Doug Penn.
                        Scott and Gale rotors are NOT the same.
                        Another aomci member, Bob Long also makes them.
                        I’ve bought from both.
