Home › Forum › Ask A Member › "Scott-Atwater" Firestone 3.6hp 1955
Viewing 8 posts - 31 through 38 (of 38 total)
  • #48258
      Just to ad to the rummer mill, I heard Doug got married
      and is wintering in Florida ๐Ÿ˜•
      #48340
      thumper
        Retroprint wont send paint to Canada! I had an American member send me a painted strip to sample and had my own mixed up
        #48343
        nali
          Duplicolor "Detroit Diesel Alpine Green" DE1618 seems to be quite correct.
          Here in Qc it’s even worse then other part of Canada to have basic products ๐Ÿ™‚
          For a cheap motor like this, it will do the job.
          #48348
          thumper
            I work on mostly Scotts but it’s really hard to get parts especially impellers now that the Scott guy passed away. Paint is available. I’m working on a 1946 the same as yours but silver
            #48354
            nali
              It seems the rubber rotor is the same as this Gale ๐Ÿ™‚
              http://www.vintageoutboard.com/collecti … ntric-type
              But I’m cheap and try to save mine by soaking in brake fluid ๐Ÿ™‚
              Rubber handle repro (urethane in fact) avalaible here ( 18$ ) :
              "Art" <adekalb@a-znet.com>
              Hope this help.
              Philippe.
              #48355
              nali
                On mine. the bottom of the tank is quite curved, and doesn t match the bottom part under it.
                Wonder if this is the result of fixing the tank with delicate but persuasive hamerring.
                Do you have the same problem ?
                Rings and head gasket here :
                http://www.laingsoutboards.com/scottmccullochparts.html
                The rings are not listed on the web site, but he has them and really great service !!
                #48403
                thumper
                  I haven’t yet but it’s possible.
                  #48404
                  thumper
                    I have heard that an OMC products can be converted to a Scott pretty easily. The 1951 10 hp can use an omc 6hp impeller, you just need to bore out the shaft diameter. That’s what a member in Florida used to restore his
