Never put the compression tester on it . Just pulling it over can tell both cylinders feel like there is lots of compression. When it did fire over in tank water was leaking out at base gasket where power head attaches to bottom end. Could see where water was coming out of gasket . Thinking maybe some water getting in crank case maybe . Actually looked like moisture on the plugs . Think that’s possible ?
