rear handle on KE7
Home › Forum › Ask A Member › rear handle on KE7
- This topic has 8 replies, 3 voices, and was last updated 7 years, 7 months ago by dave-bernard.
August 13, 2016 at 6:09 pm #4975
Anyone tried putting a Wizard handle on the back of a KE7 would nice to have something to hold onto
on the back of one? Might not look like it belongs there but could not hurt.Also how do you get the bearing out of the lower bearing holder on a KE7?
Doug
turned off?August 14, 2016 at 2:24 pm #42058I turn bearing carrier upside down loose in vice, old leather jacket on ground under it, and heat carrier around bearing in a circular motion with a propane torch. most of time bearing will just drop out into leather jacket. Propane likely wouldn’t heat carrier to point of damaging carrier but dont stay in one spot too long. There are shims. Make sure you keep track of them. Usually also fall into leather jacket for me or stay in carrier.
As far as handle goes, it should work. They also sold an accessory handle that bolted to trim ring. They show up once in a whole.
August 14, 2016 at 5:06 pm #42068yes it will fit I have them just need to replace the studs with longer studs.
August 14, 2016 at 5:11 pm #42069not sure where the shims should have been but there were no shims in there that I could find
Doug
turned off?August 14, 2016 at 6:08 pm #42072If you had none don’t worry
August 15, 2016 at 1:31 pm #42110Now I am starting to wonder if they got into shimming after the KE7… I have had 2 KE7’s apart not to far in the past and neither of those had shims as well.
quote Dave Bernard:yes it will fit I have them just need to replace the studs with longer studs.Or in the case of KE7, longer bolts. My KE7’s had bolts as opposed to nuts and studs.
August 15, 2016 at 5:25 pm #42118it originally had studs. either way they need to be replaced with longer ones. I have the handles
August 17, 2016 at 1:50 am #42208Dave got busy with another project will give you a call tomorrow
DougDoug
turned off?August 17, 2016 at 2:47 am #4221510-4
