Home Forum Ask A Member Recoil starter on 1951 TN-27 Johnson 5hp pawls not engaging
  • #237963
      Center bolt is tight, right? I don’t know what is wrong. Too bad I can’t get my hands on it.
      #237969
      stanley
        Make sure you have the little pin on edge/flange of spindle and hole on pulley engaged.
        #237977
        shafi420
          I uploaded video maybe this may help? Thanks for the inputs. I really appreciate it.
          https://youtu.be/BMiK_45LB00
          #237978
            I’m thinking that spring should be pushed up on the shoulder of the
            piece that’s bolted down, before it’s bolted down.
              I watched your video. Now go back and do what I told you to do. The spring must be preassembled up on the shoulder of the spindle as in the picture I posted, before inserting the spindle into the rope pulley. You did not do hat.
              #238304
              shafi420
                Thank you very much. I can’t thank you enough. I got my starter pawls to engage.
                I think I bent the spring a little bit so the coil of the spring was loose and not grabbing the shoulder enough.
                This motor has been sitting in my storage for over a year because I couldn’t get the starter to engage.
                It is a simple system but it really kicked my ass. Thank you again for your help.
                #238307
                crosbyman
                  thanks for the feedback !
                  #238329
                  JOHN HOLBIK
                    Franks hits another homer right out of the ball park.
