Home › Forum › Ask A Member › Recoil starter sticking – 1958 Evinrude 3 hp
- This topic has 11 replies, 7 voices, and was last updated 1 year, 11 months ago by
JACQUES.
April 4, 2024 at 4:29 pm #286506
When I tighten the screws holding the starter in place the rope won’t return. It seems the screws are pushing the recoil into the flywheel. When I loosen them it works. Thinking about trying some spacers in between the the gas tank bottom to raise it up.
As well the throttle handle seems hard to move. This is my first time working on this type of motor. I have removed the flywheel 3 times with a puller trying to get the timing right. New ignition parts and carb kit. Had it going briefly in a barrel.
Thanks,
Doug
April 4, 2024 at 6:03 pm #286507While I don’t see where the parts diagram shows spacers under your tank,
some motors come that way, and I’ve had to “tweak” several like you suggest.Did you remove the magneto plate itself, clean, inspect, and lube where it
swivels on the powerhead?
Are you aware about the tension screw on the magplate to adjust how easy
it turns?Is the motor still not starting / running as well as you like?
April 5, 2024 at 9:35 am #286518I did not remove the mag plate.
I am not aware of the tension screw. The manual I have doesn’t seem to show it.
I’m going to adjust the starter and give it another go.
Thanks.
April 5, 2024 at 10:52 am #286519make certain all parts are there
is this a new to you motor……… or just a new problem that came up after a cord change ??
Johnson Starter Group Parts for 1958 3hp JW-14 Outboard Motor (marineengine.com)
1958 Evinrude 3026 3 hp Outboard Motor Parts (marineengine.com)
April 5, 2024 at 12:56 pm #286522This is a motor given to me by my father 20 years ago. Hasn’t be going since then.
I replaced the cord. The new one is slightly thicker. I don’t think it had this problem before. Thanks for the links.
April 5, 2024 at 4:20 pm #286523203817 jw is 5/32 cord 68 5/16 inches
April 5, 2024 at 10:32 pm #286529Not smy rope will work as Crosby Man has stated. While your there remove the spring (Watch out comes out all at once). I Had several dirty with fine silt & dried grease on the rewind spring & spool. It’s a dirty dangerious job but a huge difference it makes. ASk how long has it been from the last cleaning, NEVER!!
April 6, 2024 at 8:55 am #286535When I tighten the screws holding the starter in place the rope won’t return. It seems the screws are pushing the recoil into the flywheel. When I loosen them it works. Thinking about trying some spacers in between the the gas tank bottom to raise it up.
Thanks,
Doug
Doug those motor covers can be a pain! First thing to check is the position of the side panel that the gas tank petcock is on. You might need to raise the center band that the gas tank sets on. I had the same problem on mine I shimmed the tank up and the side covers would not fit. I tore everything off and started over.
dale
April 6, 2024 at 2:28 pm #286539Anonymous
Use the proper diameter rope and see what happens.
April 6, 2024 at 2:57 pm #286540Oftentimes it is the aluminum ring that supports the gas tank that is too blame. These poor engines got knocked around, dropped quite a bit. The ring is screwed to the cylinder head in the rear of the engine, but the front of the ring/gas tank support is positioned by that horizontal bracket that is screwed to the top of the powerhead. Oftentimes this horizontal support gets bent down as well. Once the tank droops down a bit, the recoil pulley drags on the flywheel.
All that being said, probably best to make sure the recoil is properly assembled as well….
