Home Forum Ask A Member Removing Paint
  • #77256
    bill-loveland
      quote NJ-boatbuilder57:
      Whatever you use, surface prep is the key. hot water & soap, then hot water, dry it, then acetone, then naphtha….
      What does naptha do that acetone doesn’t?
      #77257
      lyks2tinkr
        I’ve had good outcomes with the self etching primers that I get from NAPA.
        The biggest challenge is getting the parts really clean and grease free. Aluminum is porous and will absorb oils.
        A good soaking in a parts washer followed by washing with hot water and dawn.
        I then let it sit in the sun and warm up which helps bleed the oils out and wash it again.
        Just before priming I will give it a light sanding with a fine scotchbrite and wipe with Acetone.
        I’ve had good luck with the rattle can self etch primers.
        #77309
        nj-boatbuilder57
          quote bill_loveland:
          Ketones (acetone, MEK, etc.) will loosen grime very well & very rapidly, and are excellent at doing so. But their evaporation rate is so fast, that you often leave the dirt and grime on the surface. Loosened, but still there.
          Naphtha isn’t as good at loosening grime as a ketone is, but the naphtha, with it’s slower evaporation rate, will finish the "washing away" part of the process.
