Home Forum Ask A Member repairing small leaks on a aluminum boat
  • #195616
    benji41
      Has anyone used the product Captain Tolley’s leak repair if so what is your results. Good or bad.
      I have a small pressure leak on a 12′ aluminum boat that does not leak when filled with water but leaks when in the water.
      Thank You for any product reviews or helpful ideas.
      Jim Benjamin
      Jim Benjamin
      #195620
        I’ve only used Gluvit (sp?) on seam leaks, which worked good.
        No experience on Captain Tolley’s product.
        stanley
          I’ve used Captain Tolleys with great success.
          #195681
          jimparrott
            I purchased an aluminum boat a few years ago that had multiple repairs to the bottom with liquid nails. It didn’t leak, but decided to weld it. I tried knocking the liquid nails off with a hammer and chisel, but it didn’t budge. I had to burn that stuff off with a oxy-acetylene torch and wire brush. Underneath I discovered cracks up to 12” long. That stuff is really tough, the boat was previously used to jump over dams in the swamp, and it really held up.
            #195813
            benji41
              Thanks to all . I am going to use Captain Tolleys.
              Jim Benjamin
              #195819
              stanley
                Capt.Tolleys is very thin so it can flow into the seam or crack.When you pierce the applicator tip,make the smallest hole possible.Also keep a damp rag handy to wipe off any runs or drips.
