Hello everyone. I have a 1956 evinrude 10 hp with a bad motor. Have a donor motor from a Johnson. I have to switch heads from the evinrude to the replacement motor because of the the cowl mounts. I’ve cleaned up all the threads inside the replacement block and cleaned up the threads on the head bolts. Question is do I need to lubricate the bolts upon installation. Thanks. Bryan.
