Home › Forum › Ask A Member › Replacement Shift Rod Connector Screw
  • #4986
    gabriel
      So I managed to loose this little important screw for my ’56 Johnson 10hp. I’ve posted a WTB but I thinking I’m could use a regular bolt from the hardware store if I knew the right size/thread count. Does anyone have one on hand to measure up?
      This is what it looks like.
      http://www.ebay.ca/itm/NEW-OMC-304024-S … 5F&vxp=mtr
      #42117
      Steve D
        Those are 1/4 – 28
        #42123
          I would not attempt to substitute that connector bolt, a bad shift rod connection will result in poor shifting and clutch dog damage.
          #42127
          chinewalker
            Stainless steel, 1/4-28 thread, 3/8" head.
            #42136
              Im not far from you, simply shoot me your address and ill pop one in the mailbox for you.
              #293986
              labrador-guy
                Yes 1/4X 28  If you have to buy some get allen head.  Lots easier to install!  If you drop that bugger down in the water pump area ya gotta pull the LU back off.   Don’ ask me how I know this.
                dale
