I ha lve an old merctronic 6-lead ‘sparky’ testing unit, but a few of the leads have broken plug terminal studs/sleeves.
So this makes it difficult getting the connections to stay put inside the coil lead boots.
Does anyone have a recommendation on where to buy some of these terminal crimping studs to replace the original 50 year old ones? I can easily cut the wires, stip, and replace if I can just find some new terminal studs.
It’s important they have a sleeve attached to the stud so that inserting them into a plug boot and terminal is easy. I considered just soldering some plug studs to the end of the wires but this would result in them being sloppy like spaghetti.
