Home Forum Ask A Member Resealing an old cork carburetor float
Viewing 10 posts - 1 through 10 (of 24 total)
  • #272089
    AZGDOGG
      Need to reseal an old cork carburetor float.
      #272090
      AZGDOGG
        Trying to get my 1936 Johnson model 100 with a model J carburetor running again. After carefully cleaning all of the carburetor parts, I am now ready to reassemble but first I would like to reseal the cork float real good prior to assembly. Any tips or suggestions and sources for a product that will reseal the cork floats and not break down with today’s fuels and lubricants? Thank you for the opportunity to ask questions and interact with others of like interests.
        #272091
        crosbyman
          sanding cleaning then fuel proof airplane  dope for hobbyst is the usual remedy  it seems
          I have used  “gel type” and lquid  crazy glue* with  small brush..it seemed to work but I have not  openned up a carb fixed this way.    Did crazy glue hold up.. hard to say
          *KEEP VAPORS AWAY FROM YOUR EYES AND LUNGS….BE WARNED !!!
          butyrate  is also used in clear finger nail polish  which you could try but  read the fine print on the bottle
          you always try to  shape a new  one out of cork then seal  it
          • This reply was modified 2 years, 2 months ago by crosbyman.
          #272092
          Steve Martin
            I use fuel proof model airplane dope.
            #272095
            AZGDOGG
              Thank you crosbyman, I will look into that.
              #272096
              AZGDOGG
                Thank you Steve, I will look for that product.
                #272097
                stanley
                  If you use ethanol free gas,you can just sand it lightly and add a coat of shellac.
                  #272098
                  AZGDOGG
                    Thank you Stanley, that will be hard to do that in my area…
                    #272104
                    stanley
                      “Tubs”AKA “The Boat House”,Is doing a long term experiment on whether cork floats even need to be coated.The assumption has been that the coating was necessary to prevent absorption of fuel.His experiment suggests it is not.
                      #272115
                        Checked the bottles. Result as of today.
