Home Forum Ask A Member Resistor Spark Plugs?
  • This topic has 7 replies, 6 voices, and was last updated 10 years ago by Anonymous.
  • #891
      In looking to order spark plugs for my 1936 Muncie Neptune OB34A, 4 hp twin,
      I found a chart that suggested using Auto-lite 386 (18mm plugs).
      They are listed as "Resistor" type spark plugs.
      What’s your thoughts as far as using resistor type spark plugs in a magneto
      system?
      Thanks, TG
        That’s the trouble with spark plug charts. They’ll tell you to use anything that fits the hole. As a general rule, resistor plugs are to be avoided in outboards, with a few exceptions. And I don’t think that Muncie would be one of them.
        #11766
        RICHARD A. WHITE
          I have an OB34A in the shop I am going to restore, ,it has Champion UD-14 plugs in it. My Champion Spark plug chart shows usage of the 6M plug
          classicomctools@gmail.com
          #11770
            Thanks for the input guys. I’ll check out the champion 6M
              Save the resistor plugs for the modern CD ignition systems.
              #11785
              jcrigan
                I Have Champion #516 or D-16 in mine. Set at 0.025". I was recommended those Autolight 386’s some time back and bought a dozen of them. They don’t work on any of our old motors.
                #11808
                  Glad I asked! Thanks, TG
                    The Champion spark plug list shows the 6M plug. The modern plug number for the 6M is a D14 #514 gaped at .025 , the D16 #516 is a hotter heat range, possibly too hot and may cause problems if used.
