Home › Forum › Ask A Member › Restoring a Johnson TN 28
  • #1625
    obnut
      The paint on the starter housing of the TN 28 I am restoring is badly chipped and there is some corrosion that needs to be removed. What is the best method for stripping the paint and removing the corrosion. Also, what is the best primer for preparing the surface for painting.
      Thanks.
      #17148
      legendre
        Regular methylene chloride stripper should be fine for the paint. You can use Aluminum Jelly to deal with the corrosion spots.. Naval Jelly isn’t recommended for aluminum, but it has the same main active ingredient as Aluminum Jelly (phosphoric acid) and the same nominal pH (~2.0).
        Is the metal beneath the paint plain, shiny aluminum – or is it dark grey, like the engine cases?
        Been meaning to ask about that.. I’ve assumed the dark grey is from alkali passivation, but would like to know for sure. Anyone know?
        #17182
        obnut
          The bare aluminium is a dull gray color, not shiny.
          #17183
            Glass beading is probably best to remove the paint and corrosion leaving the bare metal ready for a self etching primer to be applied. Glass bead doesn’t damage the metal such as sand blasting can do.
            #17187
              What Mumbles said! ^^^^^
              #17215
              obnut
                Thanks. Will go the glass bead route.
