Home Forum Ask A Member Rowboat motor 1920
  • #167707
    b-morrison
      What is the correct spark plug for this motor and are they available?
      #167716
      wbeaton
        Canada Member - 2 Years
        Which 1920 RBM do you have?
        Wayne
        Upper Canada Chapter
        uccaomci.com
        #167804
        lloyd
          It is probably a tapered thread spark plug. If and when you can determine which one it is, you can contact me directly and maybe I can provide it to you. I have a collection of very old plugs in a container in my shop. lautharr@sbcglobal.net or 231-929-7479
          Good luck Lloyd Lautner
          #168026
          b-morrison
            Evinrude model B. I have two and both had broken plugs. Thanks
            #168028
            RICHARD A. WHITE
              The pipe plugs were only on the very earliest RBM’s, I am probably safe to say that after 1913, none had pipe plugs, in fact, both my 1913’s have 7/8 inch threads….those in the 1920’s should also be 7/8 threads…If wrong I am sure I will be corrected
              classicomctools@gmail.com
              #169514
              BROOK E. NEWCOMB
                US Member - 2 Years
                Champion O COM ( discontinued number ) sure one could be hunted down without too much effort.
                Or you may try a modern Champion W 10. Both would be 7/8 for Evinrude Rowboat Motors 1913 – 1928.
                Pipe thread plugs would be used on Evinrudes 1910-1912.
                Respectfully,
                Brook
                #169524
                b-morrison
                  Thanks appreciated.
