Home › Forum › Ask A Member › Scintilla Condensers
  • #160836
    goldmember
      Anyone know where I can find replacement condensers for my KE4 7.5 HP Scintilla?
      Part #399-123
      Sierra #18-5132
      #160840
        try ebay or joe poole or oldmercs.com. or make your own. gut the cond. and replace with a capasiter .
        #160841
        goldmember
          How would I do that?
          #160842
            call me 1 914 310 7086
            #160852
              I used to use ones that came out of 140 hp Mercruiser stern drives. The engines I put them in ran fine. People really flog this condenser subject to death but my motto is, if it fits, it ships.
              #160898
              JOSEPH BRINCAT
                According to reference info that I have your condenser (capacitor) 399-123 Scintilla is rated at .17 to .21 microfarads. You can use any capacitor in the size range. Modern electronic condensers work good. Or any of the Merc Scintilla mags use the same cap. , the Mark 20 about the most common. On the OMC side, the Big Twins 51 – 56 ( pt 171471) use .20 mf cap.
                Hope this helps
                #160908
                CHUCK
                  Like you have heard from others….you can use various caps that fit physically and have the right electrical specs. If you want to consider the solid-state capacitors that many of us have found to be superior in stability and longevity…here is a link to a popular source. This link is for 0.22uf but the same vendor has other choices as well.
                  https://www.digikey.com/product-detail/en/vishay-bc-components/MKP1839422084HQ/BC2609-ND/2260507
                  Or, stick to the original equipment variety available at numerous sources. Here’s one:
                  https://www.oldmercs.com/product_p/399-123.htm
                  #160944
                    I have just had a fresh order of them come in $3.90 each plus shipping myoldoutboard@aol.com Big Rich
