I took apart the lower unit and found the aluminum tubing for the drive shaft was warn through. I picked up another one but as you can see it is much longer than the one that was in the motor. Also, the new one has one end expanded. I’m trying to find out how this should go together. Did I get the wrong tube? Can it be cut down to fit?
Any help showing me how this should go together would be appreciated.
Thank you
Bill
This topic was modified 3 years, 4 months ago by huntleybill.
