Home Forum Ask A Member Scott Atwater 1948 outboard
  • #293466
    Resurrecting an old outbrd that was in our shed for over 45yrs…put in new rings and got the engine turning over..
    Trying to find a carburator kit for AJ-17A /Tillotson
    Cleaned it up somewhat and found a cork float that is questionable and a few other items as well
    Any help would be appreciated
    #293467
    wedgie
      Thank you…
      Was hoping for a master kit that includes a few more items like needle/seat……
      Would there be another one out there that has more to the kit
      #293493
      crosbyman
        aside from a crappy float (available)  the rest should just need a good cleaning especially the idle  circuit  see 14 &16 parts
        a good soak and blast should do it
        Page 1
        #293498
        joecb
          Usually pretty easy to make a new float from cork or balsa wood. Coat it with model airplane hot fuel proof dope or super glue or even Red Coat tank sealant.
          #293526
          Thank you…the information given is most appreciated
          I will try using the same float…but if the carburetor floods out I will post and start looking for more help
          Stay warm..
