I’m putting together a 1958 Scott. In the gear case, the parts diagram shows a pin for the retainer ring. There wasn’t one there when I took this gear case apart. The pin was also missing in a parts motor I have. I can’t find a source for a replacement, but it’s not clear to me why this pin is needed? That ring slides inside the upper gear. Who cares if it runs or not? Whoever engineered the motor must have thought it was a good idea. Any thoughts?
I hope you can see where the pin would go, on the left side of the photo
