Home Forum Ask A Member Scott Atwater, 1958 10 hp, drive shaft pin?
  • #14739
      Wouldn’t at least one gear need to be pinned to the shaft so it
      turns the prop? My 5 hp Firestone is apart now, will have to look
      to see if it’s similar.
        So, I was at least half right. Not only prevents pulling it out, but also moving up and down. Makes sense now
        #14770
        jim-moffatt
          THe shift dog pins either the upper or lower gear to the shaft to get forward and reverse, In neutral both gears float on the shaft.
