Scott-Atwater 3365
Home Forum Ask A Member Scott-Atwater 3365
  • archangel
    Topics: 21
    #2286
    Two part question: Can anyone tell me what kind of compression numbers I should be expecting when I test a 1956 Scott-Atwater 7.5, model 3365? And, does anyone know of a source for head gaskets for this model? I see that Laing’s sell a number of Scott head gaskets, but they don’t seem to carry any for the 7.5s and 10s, both of which are the gaskets I require, of course
    jnjvan
    Topics: 2
    #22649
    These are not high compression engines. They will run fine with 65-70 PSI. The highest I have seen for a 7.5 hp Scott is 80 PSI.
    You might try these guys for your gaskets: http://www.discount-marine-parts.com/
    John Van
    wiscoboater
    Topics: 126
    #22666
    Americanoutboards.com has a lot of scott/ firestone stuff. They might be an option as well.
    skeg
    Topics: 18
    #22681
    Not high compression engines is correct, however, even compression between cylinders is important. Close is good.
    Kevin
    Topics: 298
    #22684
    P/N for your head gasket is 465-1882 if that helps any.
    archangel
    Topics: 21
    #22730
    Thanks to all of you. If the compression numbers are normally that low I may not need the head gasket.
