Home Forum Ask A Member Scott-Atwater/Firestone 3.6 HP
  • #6348
    patti
      What has the last year they had a rope start sheave? When did they switch from the 4 bolt head to 6 bolts. ❓
      rboatguy@comcast.net
      #53006
        Not sure about the first question. I suspect it appeared off and on over the years
        Second question, the change was made for 1947 models. Horsepower went from 3.5 to 3.6 at the same time.
        #53013
        patti
          Thanks Frank. I’m trying to acquire a 6 bolt head rope start Firestone. Do you think they made any?
          #53017
            I know they made them in Scott-Atwater version. Models 470 and 480 (1947,1948)
            #53020
            thumper
              They likely made them as Firestone as well because Firestone sold motors that were older left over scotts. The 1951 Firestone is similar to a late 40s scott
              #53024
              melugin
                The 3.6 is rated as a 4hp in the full gear-shift model Firestone single. Any difference in the powerheads, or did the gearing make a difference?
                #53028
                  Firestone continued to offer a rope start in 1949, model 133-486. Model # suggests they were leftover 1948 motors.
                  It looks like all the singles were 2-1/8" bore X 1-3/4" stroke and rated at 4000 RPM. I don’t know what they did to get more ponies.
                  AHA! The 3.6 non-shift used cylinder head # 470-1883, The 4hp shift used cylinder head # 491-1883. Both 6 bolt, but probably higher compression.
                  #53038
                  melugin
                    Frank really knows what he is talking about. Thank you.
                    #53041
                    patti
                      Are these heads interchangeable?
                      #53050
                        quote Patti:
                        My guess is that they are. Note: "Guess"
