Sea Gull 29 Four Cycle Photos?
Home › Forum › Ask A Member › Sea Gull 29 Four Cycle Photos?
- This topic has 6 replies, 4 voices, and was last updated 4 years, 6 months ago by bobw.
September 12, 2019 at 8:58 am #183159
I seen an old ad on the back of an “Antique Outboarder” of the subject
motor. I looked in my photo files and see I have no photos of that
outboard. I do have a photo of a Sea Gull radial engine, but
the “29” appears to be a conventional 2 cycle outboard, circa
1930.
Would also enjoy knowing more about the history of these outboards.
Internet searches bring no joy.
Thanks.Prepare to be boarded!
September 12, 2019 at 10:13 am #183169Did you contact Chris S? I think he has some info on the Detroiter and Seagull twin cyl 4 strokes.
September 12, 2019 at 10:29 am #183173Did you contact Chris S? I think he has some info on the Detroiter and Seagull twin cyl 4 strokes.
No, but thanks for the information.
September 12, 2019 at 8:35 pm #183209The Seagull 29 you are asking about is actually a 1931-32 Cross Seagull, built by Cross Gear and Engine Works in Detroit, Mi. This twin outboard is not to be confused with the earlier 5-cylinder radial engine that Cross built starting in 1928.
The 29 was apparently the racing version that was advertised but likely never built. The ads depicted a motor that featured dual carburetors and dual exhaust stacks that vented out the back. None have apparently ever been found. I’ve heard rumours of parts of one existing, but so far its just a wild goose chase in the making.
The service version of the Cross Seagull was offered in 1931-32. It is a twin-cylinder opposed alternate-firing four-cycle engine that was rated at 25 HP in 1931, and downgraded to 20 HP in 1932. The 1932 version I had is what I consider to be one of the most beautiful big outboards I’ve ever owned. I’ve attached some pictures for your entertainment.
In 1933, Milton O. Cross retired and turned the business over to his sons, Milton Jr, and Ralph E Cross. At that point, CG&E made the decision to get out of the outboard motor manufacturing business, and concentrate on building precision machine tools. Years later, the tooling and leftover parts were sold to an organization that became known as the Detroit Outboard Products Corporation. They refined the old Cross Seagull slightly, and named it the Detroiter. It was offered for sale in 1940. It was rated as an 18 HP motor @ 3750 RPM. Although there are ads for 1941 models, including plans for a 5 and 10 HP version, it has never been proven that any Detroiter motors were available after 1940.
To date, there are only six (6) Detroiters that are known to exist. The lowest serial number Detroiter is #2, and the highest is #25, and I just happen to own both of them.
One of the more distinct features of the Cross Seagull/ Detroiter outboards is the gas tank with two caps on it. One section was for straight gasoline, the other for engine oil that was circulated through the upper main bearing, then through the rest of the inner parts of the crankcase, thence back to the tank via a clever scavenging system. Capacities were stated to be two gallons for gas, and two quarts for oil.
If you have questions, I’m happy to answer them.
Hope this helps.
Best,
PM T2
Cross Seagull/Detroiter Special Interest Group Leader since 2005.September 12, 2019 at 8:44 pm #183214Here are some pixels of Detroiter # 25. it took a lot of work to rebuild the crankcase, but it is now a running motor.
September 12, 2019 at 9:39 pm #183221Thanks Chris for the photos and history of the Cross / Detroiter outboards.
In looking at the ad again on the magazine, I see now that it said “Utility” model,
and that it has two caps on the fuel tank. It sounds like quite the ingenious oiling system it
had….. perhaps a gravity flow “oil injection” with “anti-gravity” return!
Very interesting, and a wonderful piece of your collection!Prepare to be boarded!
September 12, 2019 at 11:21 pm #183224Those are some great looking motors. Beautiful restorations!
