Home › Forum › Ask A Member › Sea King 5 tilt problem
1959 5hp gg8977b will not tilt, in neutral. turned both ways, I’m sure it is something simple that I am not seeing. any ideas would be great!
Are you sure it’s lubricated? A few of my motors had that problem and were fine after I used a little wd40.
Duh… Knew it was something simple.. loosened the bolt and tapped it back and forth. Little lube and it’s good! Thanks!
