Home › Forum › Ask A Member › Sea King Midget update…..condenser?
  • #193734
    bill-mcnamara
      I have the new plug wire soldered in place, and coil tests out fine with my Merc-O-Tronic 98.
      Wondering about the condenser, and whether a new one is in order? I’m not quite up to speed on testing condensers with the Merc-O-Tronic yet, as the tester is relatively “new” to me.
      I’m not sure what the uf specs should be for this One Horsepower cutie, My M-O-T manual shows some uf values for some condenser #’s but the condenser unit itself is not identified.
      Would these condensers be wildly different than standard capacitors used in later OMC engines?
      Bill.
      #193735
        Your 300153 condenser is spec’d at .15-.20 A 580321 (later models) is .18-.22 Virtually the same thing, different mounting.
        #193758
        bill-mcnamara
          Thanks Frank, exactly what I was looking for.
          Bill.
