Home Forum Ask A Member Sea King Serial Number?
  • #185547
    tgenrich
      I cannot find a plate or serial number on this motor.
      Can anyone verify year and model?
      It is a 3.0 2 cylinder, starts on first pull and runs like a champ.
      Sea-King-3.0
      • This topic was modified 5 years, 3 months ago by Mumbles.
      #185573
        Early ’40s model 8814 -built by Evinrude – some parts also used on the Elto Handitwin and Evinrude Sportwin. shown here with the horse and a half single.
        #185577
        jcrigan
          There should be a brass welsh plug on the front, port side of motor, behind the carburetor. The number on this will be the model and serial number.
          #185599
          tgenrich
            Yep, on brass plug: 449 02983
            Great thanks.
            Does that tell the year?
            #185601
            eltoquad
              1938 model rated @2.8 hp.
              #185602
              tgenrich
                Wow. A 2 cylinder with only 2.8 hp.
                Thanks for the info.
                I think it is a cool motor with the cowling. And it runs great. Lots of weight for wimpy hp.
                #185609
                fifty20ne
                  Anyone know the correct spark plug for this Sea King model? 2.8 hp and 4.5 hp
                  #185614
                  tgenrich
                    Mine has Wards 14.
                    I think original plugs.
                    Sucker runs great.
                    #185621
                    jcrigan
                      If they take 14mm plugs, then a j7j set at 0.025″ would work. I use a NGK B6S or #3510.
                      #185627
                      labrador-guy
                        Check out this site, it should tell you what you want to know!
                        The 449 shows it is a 1938. Nice old motor.
                        http://discount-marine-parts.com/ob_sea_king_1.html
                        dale
