Home Forum Ask A Member Seaking 5hp impeller replacement.
Viewing 6 posts - 31 through 36 (of 36 total)
  • #198705
    dave-bernard
      carbon
      #198726
        Carbon is the correct answer–sort of. But that by itself doesn’t seal anything. Sealing requires ALL of the components working together to seal anything.
        #198734
        AnotherSteve
          frankr, where is the carbon seal assy. located?
          Ah to be young and foolish again instead of old and still foolish.
          #198735
            ?? You should have found it on the top end of the drive shaft, as soon as you removed the powerhead. Wasn’t it there?
            #198738
            AnotherSteve
              I’m sure there is seal but that I didn’t recognize it for what it was at the time.
              I bought this motor from Toms Used Outboards about ten years ago and have put many hours
              on it. Karma hasn’t let me go fishing for the past two years during which I at least turned it over every
              couple of weeks.
              I’m away from home for a bit but when I return I’ll let you know what I find.
              Thanks again.
              #198994
              AnotherSteve
                Salutations,
                There is a carbon seal assembly in the motor frankr.
                I’ve ordered replacement pieces as needed to include the seal itself.
