Home Forum Ask A Member Search function in Ask A Member
  • #287038
    cron78
      Can logged-in members search in the new layout?  I can’t find where to do so.
      #287049
      seakaye12
        Sure.  Go to Members Only/Active Member Forum.
        There is a Search field at the upper right of the page.  Seems to be working nicely if you want to search our forums.
        #287074
        Pondrocket
        Keymaster
          Search function is a Member Benefit & in Members Section.
          Thanks
          Travis
          AOMCI VP Communications
          AOMCI Webmaster
          webmaster@aomci.org
          #287087
          Shear Pin
            Searching someone’s post  (Topics Started – Replies created) still doesn’t work past page 1.
            #287098
            Pondrocket
            Keymaster
              Shear Pin we are aware & working on. Thanks
              Travis
              AOMCI Webmaster
              webmaster@aomci.org
              #287123
              Shear Pin
                Thanks for your, and others, efforts. That will be great if you can work it out.
                #287128
                T….in Wisconsin
                  Nice feature, worked for me!
                  #287130
                  Shear Pin
                    It will work for your post. Try searching someone else on page 2 or higher.
                    #287132
                    T….in Wisconsin
                      <header class=”page-header”>
                      Are you using the search box on the “Active Member” Forum Page?
                      Active Member Forum
                      </header>
                      <form id=”bbp-search-form” role=”search” method=”get”>
                      <input id=”bbp_search” name=”bbp_search” type=”text” value=”” /> <input id=”bbp_search_submit” class=”button” type=”submit” value=”Search” />
                      </form>
                      Home  Forum
                      Welcome back
                      There have been 0 new topics and 2 new replies since your last visit at 8:29 am on April 21, 2024.
                      #287150
                      Shear Pin
                        Open “AOMCI Website Update” in Dock Side.
