Home › Forum › Ask A Member › Sears 12HP
- This topic has 7 replies, 5 voices, and was last updated 6 years, 11 months ago by amuller.
April 22, 2017 at 9:03 pm #6817
I have inherited a Sears 12HP outboard Model 571-59271 Serial Number 59271.1017. I have learned that it was built by Westbend in 1965 but can’t find any parts for it. It is in great condition but needs a water pump impeller. Any idea where I could find one?
Thank you,
BillApril 22, 2017 at 11:49 pm #56558These guys might be able to help you out. I’ve never used them before, so I can’t vouch for them:
Interestingly, this website (that I have ordered from before and can vouch for, says your motor is a 1960 7.5HP). They could have parts too:
http://discount-marine-parts.com/ob_elg … model.html
And then this site looks like it has some good general info:
http://www.oddjobmotors.com/west-bend.htm
Good luck to ya!!
April 23, 2017 at 1:51 am #56560Here’s a PDF with a somewhat abbreviated service manual for the West Bend 12.
http://www.fiberglassics.com/library/im … ual002.pdf
April 23, 2017 at 11:43 am #56572Thanks guys!!
Looks like I need to find someone who reproduces impellers? Anyone out there that does it?
BillApril 23, 2017 at 1:56 pm #56580You might need to go that route. You submit your old "core" and the new vanes are added. Before you go that route you can check with member chrysleroutboarddude to see if any of the available Mercury/Force/Chrysler impellers will work….or if he knows of another similar impeller from some other application that would work with perhaps some minor modifications.
I just installed a $15.00 OMC impeller in a Chrysler; the genuine Chrysler impeller (from Mercury) costs $125.00! So; there are sometimes solutions that are not readily apparent.
Here are a couple of sources for "made to order" impellers:
Bob Long (Flying Scott)
http://home.earthlink.net/~flyingscott/index.htmlBrian Wilcox:
Baron0418@att.net. Please note the B must be a capital Or 810-794-7685 before 8 pm est pleaseApril 23, 2017 at 2:31 pm #56583I am about 99% sure this impeller will work in the 12hp West Bend
http://www.marineengine.com/newparts/pa … -00194.htmApril 23, 2017 at 10:47 pm #56601quote B-Dittmar:I am about 99% sure this impeller will work in the 12hp West Bend
http://www.marineengine.com/newparts/pa … -00194.htmThank you!! I’ll give it a try.
BillApril 28, 2017 at 12:13 am #56742If that motor is a 12 hp West Bend from the 60s there is a Sierra impeller that will fit. Most likely the one listed above. Chrysler bought West Bend and continued many similar motors. Take a close look at the starter pinion and be gentle with it. The are a weakness of these motors and not always readily available.
