Home › Forum › Ask A Member › Sears game fisher
- This topic has 16 replies, 6 voices, and was last updated 9 months ago by
LARRY CATON.
October 7, 2024 at 3:33 pm #291399
Hello: I just recently picked up a 7.5 hp Sears game fisher. Unknown year. I cannot find the serial number on it. The engine is a Tecumseh 710405a single cylinder aircooled water cooled exhaust engine. Turns over fine but no spark. I am looking for a coil and a set of points and condenser. Also a carburetor kit or replacement carburetor. Hate to give up on it looks like it had little use. Any assistance would be welcomed.Thanks jim
October 7, 2024 at 5:02 pm #291401carbs frequenetly just need a clean up… no kit
spark wise try just a good points clean up… coil may be perfectly good. condensers…. well they are likely bad
October 8, 2024 at 5:30 am #291413James, Have you had the flywheel off yet and determined that in fact that motor has a conventual magneto with points , coil and condenser? Some of the later Gamefisher’s had an electronic module controlling the ignition.
October 8, 2024 at 10:41 am #291419James, Have you had the flywheel off yet and determined that in fact that motor has a conventual magneto with points , coil and condenser? Some of the later Gamefisher’s had an electronic module controlling the ignition.
Yes James lets see a pic of the engine and the mag plate. Once we see what it looks like I’m sure someone can come up with a parts list and suggested service procedure. My experience with those is that the coils are usually good, points can usually be cleaned and condensers can be replaced inexpensively with something from NAPA or similar.
October 8, 2024 at 11:55 am #291421some info on IBOATS… do a search
October 8, 2024 at 1:57 pm #291423Hi. Thank u. I Will try and post pictures of the power head. Yes it is a points an condenser motor
October 8, 2024 at 1:58 pm #291424James, Have you had the flywheel off yet and determined that in fact that motor has a conventual magneto with points , coil and condenser? Some of the later Gamefisher’s had an electronic module controlling the ignition.
I will try an post pictures it is a points and condenser engine
October 8, 2024 at 1:59 pm #291425James, Have you had the flywheel off yet and determined that in fact that motor has a conventual magneto with points , coil and condenser? Some of the later Gamefisher’s had an electronic module controlling the ignition.
Hi yes I have. It’s definitely a point and condenser ignition for this motor
October 8, 2024 at 2:01 pm #291426James, Have you had the flywheel off yet and determined that in fact that motor has a conventual magneto with points , coil and condenser? Some of the later Gamefisher’s had an electronic module controlling the ignition.
I will try and post pictures
October 8, 2024 at 4:09 pm #291427James, Have you had the flywheel off yet and determined that in fact that motor has a conventual magneto with points , coil and condenser? Some of the later Gamefisher’s had an electronic module controlling the ignition.
Site won’t allow me to post pictures says too big to post. Any ideas on that one ?
