Home Forum Ask A Member Shark bite!
  • #3129
    davidk
      Hey, speaking of West Bend Sharks…..my 18 hp has a chomp out of the anti-cavitation plate. My 16hp parts motor has a very similar situation. Is this a common condition with these motors? Anybody got an 18 parts motor with an intact lower leg. Besides that, it runs great. Even the dash light works so I can read my lake chart and find my way home. Okay, full disclosure, I haven’t really had it out at night, but it works in the barn!
        I had a twelve and an eighteen and neither was broken like that!
        #28247
          David,
          If you know a decent welder, he can fix that in no time.
          Make the cut straight, tack on some matching material, then cut the arc.
          I haven’t done a spot that large, but for chips that is the technique I use. Cut out a square, cut out a piece to match, weld in, then polish out weld and paint.
          #28249
            I’d say it was a "great white" shark.
            david-bartlett
              David,
              I noticed the material is a bit thinner than the Johnson/Evinrudes of similar vintage. Like Chris suggested, a good welder could probably make that as good as new. I will keep my eye out for any WB parts motors though.
              I can’t wait to play with the Night Light on mine!
              #28260
              brook-n
                Being a West Bend "Shark" I would leave it, plus it looks cool. Just this of the fun stories that could be made up at the local boat ramp! " Your gonna need a bigger boat"
                Respectfully
                #28271
                wiscoboater
                  The dash lights are the coolest feature on the motors!
