Home Forum Ask A Member Shift Handle Bushing QD16
  • #290778
    Rob
      Hi Everyone,
      I am working on a QD16 10hp Johnson and the shift handle is really loose in the housing (midsection?).  I think a nicely machined brass bushing would fix it up nicely, but I don’t have a lathe.  Does anyone on here do that sort of thing?  Or is there a better idea for fixing the slop in the shift handle?
      THANKS!
      –Rob
      Rob
      #290784
        I know some of those can be fix up using some brass tubing available at hobby stores.
        If I don’t find the information, search on site and see if it pops up, or someone
        will probably have the data ready available.
        Rob
        #290785
          Got a drawing of what you want made, including accurate dimensions?
          Rob
          #290786
            OR perhaps it’s something you can make for yourself?
            Speedy Metals 1/2″ OD x 0.370″ ID x .065″ Wall Other Brass Round Tube
            Rob
            #290787
            Steve D
              Mumbles had a good fix…. https://www.aomci.org/forums/topic/johnson-cd12/
              A number of ebay sellers have the brass stock as well as some hobby shops, hardware stores, etc.
              https://shorturl.at/vSxMg
              Rob
              #290788
              Rob
                Thank you, sir!  I think I’m going to give this a try!
                Rob
                #290789
                Rob
                  Thank you sir!  I think I am going to give this method, combined with FrankRs’ suggestion a try.  Seems simple enough; drill the hole out, push in a brass sleeve from the hobby store, and glue it in with what I assume is JB weld.
                  THANKS to all of you for the help!
                  –Rob
                  Rob
