Home › Forum › Ask A Member › Shift rod bushing replacement? Evinrude Lark III
  • #210221
    mr-asa
      I seem to remember you take a tap and thread the bushing, then screw in a bolt and knock it out? What size thread is that? Other tips for the job?
      #210226
      RICHARD A. WHITE
        I believe you can again buy the tool from OMC, if memory serves it is like $10…
        classicomctools@gmail.com
        #210230
          5/16-18. Run the tap in just a few threads, then the bushing can be reused.
          #210249
          mr-asa
            I picked up a new one. Trying to make sure I don’t have to worry about this motor for as long as possible. Thanks, Frank
            #210581
            GLEN DEUTSCH
              You can make a tool using a long spade bit and grinding off the point and edges of the bit. The other end,the end that would go into the drill, will fit nicely into the bushing. The bit thickens after about two inches and the bushing can be easily driven out. No need to ruin the bushing by tapping
