John, from what I hear, its common for that front rubber mount to be broken, Looking on flea bay, most replacements are about $50, Being cheap, I looked for a less expensive fix. I believe that I have found the solution, a universal bubbe vibration isolator ( mcMaster Carr #9213K18 – $4.62) is just the right size to replace the sheared off rubber in the motor mount. Drill, tap and install. All looks good, I will report back on total success once I get the motor re- assembled.
