Home Forum Ask A Member Shift shaft ”O” ring. installation technic on OMC lower units
  • #287901
    billy-j
      When installing the shift shaft ‘O’ ring in OMC lower units What is the best method for success in creating a long-term seal. Is it best to install O ring and tapping retaining bushing till it bottoms on O ring then pushing shift shaft thru O ring. Or pushing shift shaft thru O ring then tapping in the retaining bushing with a section of pipe or tubing to bottom on O ring? Also is it proper to bottom the retainer on O ring? And finally, some lower units have a fiber washer installed with O ring and some do not seem to have fiber washer. Should the fiber washer be installed above or below O ring when it is installed in lower unit bore and what is the fiber washers function.
      #287905
      fleetwin
        US Member - 2 Years
        This is an interesting topic.  I usually use the OMC tool, so the shift rod is not in place.  But, there surely is a good argument for having the shift rod installed first through the oring to make sure it is oriented properly  The next question is a great one as well.  How far do you tap the bushing in.  There is no spacer to bottom out on, in most cases, and driving the bushing in too far will probably distort the oring and lead to leakage.  I usually try to make a note of how far the bushing was tapped in before removing it, and try to reset it to that position.
        Some newer models have a bushing that encapsulates the oring and bottoms on that plastic spacer, this takes the guess work out of the equation for sure…
        Once I have driven in the new oring and bushing, I usually take a grease gun to fill that cavity with grease before installing the shift rod…
        #287906
        crosbyman
          I just remove the bushing   intsall o-ring … re- insert the bushing tapper down against the o-ring ….   polish the shift rod to remove any  corrosion or  roughness  and  slide it delicately down with some oil.
          #287925
          billy-j
            The grease is a good idea. Thanks
            #287926
            billy-j
              This is how I have been doing it. I just wondered what others did also. Thank You.
              #287927
                US Member - 2 Years
                In the past I removed o ring , spacer & shift rod. Next I clean all mating surfaces, then lube the o ring & shift shaft & with inert lube &install shift shaft in the upper case then slide the o ring down the shift shaft until seated in the case. slide the retainer bushing down & tap into place. This way I can adjust the o ring tension with shift rod in place.
                #287937
                billy-j
                  I am going to try your method next time I do a shift shaft O ring. What did you use for an inert lube? Another post said after he installed O ring he pumped some grease into the retainer/O ring cavity and I thought that was a good idea too.
                  #287952
                  fleetwin
                    US Member - 2 Years
                    OK, I do pump some grease in there, but after the bushing has been reinstalled.  Filling that cavity with grease beforehand might loosen the fit between the bushing and gear housing causing it to slip back out of there…
                    #287965
                    aquasonic
                      When reinstalling the bushing, tap the bushing down until the top of the bushing is flush with the bottom of the chamfer at the top of the opening. I had the same question. Frank Robb had the answer.
