Home Forum Ask A Member Sierra Low Unit Seal Kit Charts?
  • #287603
      Anyone have a Sierra lower unit seal kit chart / list for the 50’s & 60’s OMC
      outboards? The only one I have is for much newer units.
      Thanks.
        Buc – here’s one on Marine Engine that goes back into the 50s and 60s.
        https://www.marineengine.com/parts/sierra-marine/quick-list/johnson-evinrude-sierra-gearcase-seal-kit.html
        #287617
          Thanks Bob. I thought ME might have had info., but I couldn’t find any link
          to it on their homepage. Bookmarked now.
          Strangely, they don’t list a seal kit for a 1956 QD 10 hp that I may be
          working on for my cousin.
            Nope, that has that prop shaft seal that Sierra doesn’t have available
            #287640
              Also OMC’s version is N/A anymore either.
              Looks like the best bet is a CR 6280
              Inches (IN) Millimeters (MM)
              Shaft 0.625 15.88
              Bore 1.250 31.75
              Width 0.313
                National Seals #471264 also works for that size shaft and housing bore, but is 0.250 in width and their #470018 seal is 0.375 in width.  The CR seal you found is likely the closest fit to original.
                #287647
                  Thanks Bob, I ordered the CR 6280 last night.
