Home Forum Ask A Member Silicone to replace power head base gasket?
  • #4854
    adam1961
      Does anyone use some kind of silicone or RTV in place of the base gaskets on Classic OMC motors? I find myself going through many gaskets on the motor that I run on my racing runabout. It seems I am always pulling the power head for one reason or another. Is it possible to use a sealant, or should I just keep replacing the gaskets( one on each side of the stainless baffle) ?
      Adam
      #41034
      fleetwin
        Adam, I would not try to substitute RTV/sealer for base gaskets. You could try just coating the new gasket on both sides with grease so the powerhead will come off without damaging the gasket during future repairs.
        #41035
        drifter
          On a similar note, I have a repair manual that shows a head gasket (on a 57 Johnson 10hp) being replaced with anti-seize compound covering both sides of the gasket. I never tried it but wondered why they did this. Is this a normal repair practice?
          #41047
          fleetwin
            Drifter, would love to know what kind of manual would make a recommendation like that….Some of that anti-seize stuff can actually promote corrosion when mixed with the aluminum and salt water. Yes, I realize that the anti seize company does make aluminum compatible products, but they would have little value when it comes to sealing a head gasket.
            The best stuff to use when sealing head gaskets is the OMC/Merc gasket sealing compound. Using the gasket sealer around the outer edges of the head gasket is all that is needed, this will not help seal a fault in the cylinder to head surfaces, although it surely won’t hurt to apply there as well.
            #41049
              Aluminum paint used to be the sealer of choice for automotive copper composition head gaskets! ☺
              #41058
                Adam1961
                Sent you a PM.
                #41065
                drifter
                  Well, I was almost correct. The manual is a book titled "The Classic Outboard Motor Handbook". Page 91 shows a photo of a man brushing anti-sieze on a 1958 Johnson 10hp on the block where the head gasket mates to the block. The photo caption reads:" A gasket sealing lubricant is applied to the water jacket and cylinder assembly surfaces".
                  I always thought this was weird.
                  Drifter
                  #41097
                  amuller
                    quote fleetwin:
                    I’ve wondered if the copper loaded anti-seize is really OK to use with aluminum. Is that what we are talking about here?
                    #41098
                    PugetSoundBoater
                      You do not want to use anti sieze with copper on Aluminum in it due to the galvanic corrosion/dissimilar metals issue. I use Jet Lube Marine Grade Non Metallic Anti sieze.Fastenal stocks it. Locktite makes one also.
                      Robbie Robertson
                      #41108
                      collectorinspector
                        I do not believe that silicon or RTV squeeze of any type should ever be used……….
                        Plenty of old school gasket/sealant/preparation with some attention to detail before assembly is the ONLY thing required.
                        Just saying.
                        BnC
