Home Forum Ask A Member SouthBend A Stuck Piston
  • #279100
    stanley
      I have used grease to move pistons as well however I would consider it a last resort with risks.The first time I did it I cracked the cylinder bore.On old motors the wall can be weakened by rust on the water jacket side,
      #279104
        Tubs, Good info.  Looks like you would have had to block off the intake passage too once the piston moved down a little way.
        And another caution for Tim, from his photo, looks like the cylinder is from an opposed twin, hence the off-set conn rod. This will present an issue if attempting to pull on the rod, as it not a straight pull like on Tubs cylinder. Even more likely to damage the rod.
        The assembly pictured is from a 1924 Johnson
        Model B having off-set connecting rods.
        #279209
        george-emmanuel
          I recently removed 2 pistons for a new member. Fabricated a puller with cable going around the wrist pins so no pressure was applied to the rod and used eye bolts. I did weld the eye bolts so they wouldn’t open during tension. The frame I made is well away from the cylinder flange to keep pressure from breaking a flange. Got both pistons out and saved the rings….but as everyone has said so far, take your time.
          #279217
          T….in Wisconsin
            Disappointed to report I was not able to salvage the jug.
            Rust and corrosion had weakened the water jacket which cracked when I applied heat.
            Piston & rings are most likely in poor condition also.
            Sidelining this project for colder weather.
            Thank you to all for taking the time to share your information.
            #279236
            joecb
              Tim, don’t give up on it yet. If the crack is just on the outside of the water jacket the jug may be usable. Since that kind of a crack won’t be contaminated with oil, maybe seal with a penetrating anaerobic like LocTite green wicking grade. Just water and no pressure there.
