The book sez, ’39 – ’47 Sportman motors were equipped with Champion H-10J plugs gapped at .025″. You’ll have to do some searching to find a modern equivalent to that plug.
I’m thinking H is the thread length and 10 is the heat range. J style plugs with the shortened ground aren’t made or needed anymore.
Mumbles has it about the H, the 10, and the J.
The Champion H10C is the closest – easily obtained –
replacement I know of. It has the 11.2 mm thread
reach as did the H10C but the end of the ground
isn’t centered over the electrode. A file can change
that if one likes.
Tubs.
