I looked on Brillman’s before I posted and failed to see them. Thanks!
It doesn’t say on their site, but did you need a special tool to criimp
the rings?
Also, they show a tiny tube type of terminal end, while not original,
would probably work on outboards as well. https://brillman.com/product/spark-plug-eye-terminal/
This reply was modified 4 years, 4 months ago by Buccaneer.
Those ring terminals will all do the job, however they are not like the original style. The old ones had a “tail” or spike that pushed into the wire insulation in addition to the “ring”. This tail helped straighten the connection and reduce the tendency of the wire breaking at the joint of the wire insulation and the ring.
Samuel Phelps US Member - 2 Years Replies: 229 Topics: 40
Your right the one’s I had did have the little spike on the bottom .
The little tube type were out of stock …
I’m gunna try a pair of needle nose to crimp ..
This reply was modified 4 years, 4 months ago by Samuel Phelps.
