Home › Forum › Ask A Member › Spark plug wire boots – OMC 510289
- This topic has 8 replies, 7 voices, and was last updated 6 years, 7 months ago by
burnt-clutch.
February 12, 2020 at 12:29 pm #194578
Do you all use a substitute part for the spark plug wire boots that seal the plug wire to the coil? I’m putting coils on my ’54 Fleetwin and don’t have any boots for the plug wires. Is there a Sierra marine equivalent to OMC 510289? I’m hoping to score something at my local Auto parts store if I could. Thanks in advance for your input.
-KarlFebruary 12, 2020 at 12:34 pm #194580I’ve heard of using a small piece of heat shrink tubing to replace the boot but haven’t tried it myself.
February 12, 2020 at 2:21 pm #194587If you are installing new coils,, 510289 is the wrong boot. That was for the old coils with a fatter snout. New coils “usually” come with the proper boot.
EDIT: Boot for the new coils is 0510964. They are mighty proud of them
This reply was modified 6 years, 7 months ago by
frankr.
February 12, 2020 at 2:27 pm #194588Good call. I’m installing coils off of a parts motor and these are a Zinc chromate green color and the snouts are tapered. The PO of the motor used Automotive plug wires and didn’t use a boot when he put them on the coils. Would RTV be a workaround if I cant find any boots?
-KarlFebruary 12, 2020 at 2:34 pm #194590Actually do we need the boots on the coil end? They can be very difficult to install on that end and adjust the coil position.
February 12, 2020 at 2:57 pm #194596You won’t score at the NAPA store. Sure you want the 510289, send me an email. Ed Elliott eddelliott@cox.net
February 13, 2020 at 9:16 am #194665I put a small ring of Liquid Nails Clear Seal around the plug wire and then push it into the coil. Creates a good seal and makes for easier coil installation.
February 13, 2020 at 9:53 am #194672I usually add a touch of dielectric grease all around but …………I like the heat shrink solution next time I install I will try it out
I make a small mark on the wire about 3/8 to 1/2 from the edge so when I screw in the wire on the post I know how far it went in on the screw post
February 19, 2020 at 11:08 am #195345I ended up putting a bead of Yamabond RVT sealer around the wire and then seated it in the coil snout. Thanks for all of the replies.
-Karl -
