Home › Forum › Ask A Member › spark plug wire end terminals
  • #1532
      I was going to put new plug wires and terminal ends on the Firestone mag,
      and pulled out some new terminal ends that I took off a different outboard
      because they didn’t look correct. I noticed on these NKG terminals,
      they said 10K Ohms on them. Sure enough, that’s what they test.
      I presume these are meant for automotive use, not old outboards???
      Thanks, Buccaneer
        They are probably for CD ignition. I know Honda and Yamaha both have resistor spark plug terminals on their CD ignitions. They tend to fail after time and I’ve replaced them with regular Sparkie style terminals and they run just fine.
        #16401
          Thanks Mumbles. Guess I better look for a cheap source of 90 deg.
          terminals with boots so I have some on hand.
          legendre
            10K NGK terminals (like LB10F) are typically found on motorcycles. They aren’t appropriate for outboard motors in almost all cases.
            There is currently an eBay seller who is offering 90′ NGK terminals without a resistor for under $6.00 per set, shipped. I bought a set, and they are just great.
            Quality is much better than the typical ‘sparky’ type cap.
            #16418
              Brillman has the original Sparky style but you might want to call them first to see if they are black or blue.
              https://www.brillman.com/store/product_ … n-terminal
              #16432
                Thanks for the leads on the terminals….. I’ll check them out!
                  If you need them today a boat shop has them + no shipping $$ either.
