Home Forum Ask A Member spark plug wires
  • #174326
    cookjer24
      so got my 1959 golden jubilee 5.5 fisherman out for the year.went to start it only runing on one cylinder well after swaping coils and condeners and cleaning points..same thing no spark…found a small pin hole in the plug wire cut and redid conection now it works…but the ohter plug wire is bad ..it cuts the cylinder out at certian throttle spots..so what and where do you get the solid core plug wires for it or can you use regular auto wires.
      #174331
        Depends on where you are. Some auto parts stores carry it, but many do not. Other possibilities:
        Truck / tractor / farm equipment stores, or auto parts stores that cater to farmers.
        Lawn mower shops
        Boat motor repair shops (duh)
        e-bay.
        on-line marine motor parts places
        No, do not use carbon core auto wires
        #174333
        cookjer24
          i found some on amazon it stranded copper should work the same..no one in my area has solid copper wire..so 11 bucks for 10 feet of the stranded isnt bad in my book
          #174340
          crosbyman
            get 7mm wire
            #174341
            cookjer24
              yep it is 7mm
              #174342
              chuckw
                US Member - 2 Years
                Brillman company has Packard 440 wire. It is what I use on all my motors.
                #174347
                  7mm Stranded copper is what you want. I don’t think there is any such thing as solid copper spark plug wire.
                  #174402
                  cookjer24
                    yep there is solid copper wire..that is what on the motor right now…but stranded will work the same so that is what i got…cant wait for next week when it comes in…get it put together and go out run it for hours around the lakes…by chance does any one know if you put small amount of grease on the bottom side of mag plate when you reinstall it or leave it dry.
                    #174403
                      Grease it and mounting rings sparingly. Too much will just slop out and foul the breaker points.
                      #174404
                        US Member - 2 Years
                        Have a neon shop close? Can get Hi Flex G.T.O. high voltage wire in any color you want & yes 7mm. Been using it in my 18hp Johnson 1958 for years now.
                        Very fine strands for easy flex, rated at 15,000 volts. G.T.O. = gas tube only
