Springs on starter-6 volt 1955 RDE-17 25 hp Johnson
Home Forum Ask A Member Springs on starter-6 volt 1955 RDE-17 25 hp Johnson
  • outboardnut
    Topics: 419
    #150941
    Like a dummy. I took apart a perfectly good starter to clean the commutator.
    Before I bend those brass studs anymore. Can someone give me any advice on putting on the springs.
    brass stud
    spring on
    Topics: 1074
    #150975
    I think I would just start the spring on the tangs using a needle nose
    pliers, recoiling the spring enough to get the end back in the brush
    holder.
    outboardnut
    Topics: 419
    #151055
    The spring starts going cockeyed
    vintin
    Topics: 19
    #151165
    Can you use pieces of string to hold the springs in place and pull them out as you slide the motor together? I’ve done it before on a briggs and stratton starter.
    outboardnut
    Topics: 419
    #151171
    I knew there was a trick!
    Thats why I have that old fishing line!
    I will give that a try.
    Thanks
    Topics: 51
    #151403
    Lift the springs out of the brush holders and rest the ends on top of the brush holders. That takes the pressure off the brushes so they can slide onto the communtator. Then release the springs.
    outboardnut
    Topics: 419
    #151454
    ahhhhhhhhhhhhh
