Home Forum Ask A Member Spun prop hub
  • #161696
    majorramifications
      Hey guys,
      With your help, I finally got my ’63 Gale 15D15B running like a champ, but now the prop hub’s a spinnin’ but the prop, well not so much. If there is a cheap way to fix this, I haven’t found it.
      Apparently, my options are:
      1) Buy a used prop that is still good
      2) Buy an NOS prop
      3) Buy a comparable but still available new OMC prop
      4) Buy an aftermarket (like a Michigan Wheel) prop
      I’d rather not go through this again, so the first two options don’t appeal to me. I figure it’s just a matter of time before the old rubber in them craps out. Am I being paranoid?
      My main question is:
      Are the new factory parts from BRP considerably better than the aftermarket?
      #161701
      dave-bernard
        If the prop is in good condition get it rehubbed
        #161724
        lindy46
          Most dealers can get this done (they send them out). Usually runs $40-50.
          #161737
            It might be easiest to just replace the prop with a ‘known to be good’ used one. Any 10, 15, 18, 20, or 25 horse pin drive prop from ’51 thru ’77 will fit your motor except for the the ’58 – ’63 ten horse ones. Being only 15 horsepower, I’d stick with a lower pitch one to prevent lugging the motor.
            #161750
            rmhxruss
              A new prop may be the best option. Yes hubs are semi cheap but labor can be expensive and freight both ways will add to the cost.
              #161878
              tkwalker
                Like previously stated above… The best and most inexpensive way to go is get it rehubbed … $40 to $50, here in Middle Tennessee …. TK
                #161968
                majorramifications
                  I didn’t know that re-hubbing was an option on these props. There is a prop guy at one of the outboard dealers that I buy parts from. He sings while he works, but I didn’t know it was possible to re-hub this thing. I’ll go see him next week.
                  Thanks guys!
                  #161989
                    You guys are getting a deal down there as we have to pay at least that amount to get just the hub and then shop labour on top!
                    There’s lots of hubs to choose from in the following PDF so take your pick.
                    HMS-Prop-Hubs-Pictures
                    #162075
                    A Hoskins
                      If you have ever watched the re-hub process you quickly realize that you could do this yourself. You need a press, but even an arbor press will do fine. Hubs are available from a number of sources.
                      "Fox News" isn't.
                      #162109
                      tkwalker
                        Now to clarify things , dealers down here usually will not rehub … They send them out to our Prop shops which only specialize in prop repair … That keeps the $$ down … Dealers labor rates are out of site ! TK
